Memory leak with webproxy
I have amd 1.3ghz with 512mb ram and MT v2.9.18.
The memory usage is coming down from 318mb to 53mb (example values) every 3 or 4 days. If i disable and enable the webproxy the memory usage come to 318mb.
I have to do an script to disable and enable the webproxy, but my question is:
there is memory leak for webproxy??? the webproxy is NOT the webproxy-test.
Regards.
Maximiliano
Hi.
I have the same results. AMD 1.8, 1 GB Ram. Memory droping from 720 to 40 mb after 2-3 days. In another location have CELERON 2.6, 1 GB Ram. After 11 days uptime lost only 60 mb ram. Isnt “function” amd processor or motherboards problem?
