Memory linitations?
I got a “Bug in Dude 1.2: ALLOCATE 0 in unsigned int nv::Allocator:allocate() at common/alloc.cpp” at line 100 something.
Does this mean I can’t discover a class B (only 65k addresses :stuck_out_tongue:) with The Dude? Or is that just a limitation of the GUI for one map?
And yes I was strain testing it by doing a full discovery (fast ping scan with service scan + all options on the last tab checked) on a class B network (the address space was not full)(update:) to be more precise it discovered 2053 before popping up
You should upgrade to newest beta and see if that fixes the problem
