memory manager error info debug error mikrotik
i have this memory manager error info debug error mikrotik
I want to Solution the problem
Use a MicroSD or USB, and run user-manager database off it, you’re running out of space.
Which routerboard are you using?
i’m using
hAP ac lite : RB952Ui-5ac2nD
https://mikrotik.com/product/RB952Ui-5ac2nD
Please solve the problem with the explanation
You will have to add a USB memory stick to solve the problem.
