Menu Item: /Routing/table missing
Hello.
Am running RouterOS version: 6.49.2 (stable) with 2 WAN links and a private network.
Am following the Mikrotik Docs article on FAILOVER (WAN BACKUP)
For some reason my unit seems not to have the /routing/table menu to add the fib as proposed in the section
/routing/table
add fib name=to_ISP1
add fib name=to_ISP2
Has this been deprecated in my version of Router OS?
Is there a current guide on how to FAILOVER with 2 WAN Links? I don’t want to do LOAD BALANCING as the 2 links are asynchronous ie not of the same bandwidth.
That help page is for ROS v7. Use old wiki for v6.
Did you say load balancing… have fun this is really good!!!
https://mum.mikrotik.com/presentations/US12/steve.pdf
