merge 2 wan --main traffic with google peering line
hi
i have 2 wan
wan1 — 100 mbps (internet leased line)
wan2 — 100 mbps google peering
how to combine 2 lines so if i use google services traffic goes to wan 2 if i use facebook and other sites goes to wan 1
pls suggest…
Do you have your own AS no. If yes then establish both bgp in core router . Google traffic is automatically forwarded to google routes.
Sent from my MI MAX using Tapatalk
I dont have as number but i have 100 mbps google peering connectivity now how can i merge both lines
You can create google ip address list and mark google packets ,and set google peering route to marked packets.
Mail me on :parmarshailendra47@gmail.com
Hi Team
I have same situation .wanted to know how to do the configuration on router so that i can use the peering ..
wan 1 :- ISP1 -310 Mbps
wan 1 : ISP 2 - 500 Mbps- google-Peering
BGP
i have my own AS number .share to both ISP .
bgp has been establish with both .
in Peering i have prifix count is 900 approx .
what should be the default route or any policy .
thankssss
Can someone help me as well, I have same issue
We have 2 links one Internet and done peering from IXP.
WAN1 - 100mbps
WAN2 - 500mbps
It would great if you help me out from here,
I don’t know how to configure in Mikrotik router.
And I don’t have AS number as well.
