MERGE 3 DSL
HI EVERYBADY
sorry my language not very well
i have 3 adsl lines each line 1 mb
so, i want to merge it and balancing the download and upload also (if one or two lines from my three lines were cut i want the internet is on from the line that is on)..
thanks for help me :smiley:
Ask your ISP if they support DSL bonding.
otherwise, you could use load balancing to send each packet through a different gateway (could break some programs that use many connections), or use policy routing, to send different kinds of traffic through different gateway. for example WWW through one, VoIP through other and rest through third.
THANKS FOR YOUR REPLAY
is that possible in mikro tik to balancing the download in my network?
You can find an example and explanation of policy routing on my blog here: http://blog.butchevans.com/ (do a search for “policy routing”)
http://wiki.mikrotik.com/wiki/PCC
