Merge Eth & wLan as one
hi there,
very new to routerOS, im rnning a RouterBoard411ah. Basically trying to get the wLan to be and extension of my switch port on my cisco.
hoping to make the eth transparent on the mikro to allow just for a wireless extension.
{switch vlan 10.4.10.2} <-------> [Mikro/AP wireless network 10.4.10.101]
Apologize for not being to detailed, i’m typing this from my phone.
thanks in advance
bridge wlan interface with the Ethernet interface port of Microtik.
Create bridge and add Ether 1 and Wlan1 as ports. This will create transparent link comparable to having lan cable between two points.
Perfect thanks guys, figured that out just after i posted this thread.
appreciate the hastily response.
Cheers. :smiley:
