how i can Merge two ADSL Lines together in mikrotik to work good with PPP
i have two Routers
Router 1 → 10.0.0.10/24 - WAN1
Router 2 → 11.0.0.11/24 - WAN2
Switch → LAN → 40.0.0.40/24
thank you for help
i have two Routers
thank you for help
Merge or load balance? Here is a link for load balancing. You won’t be able to merge the data without using BGP or such.
i try it but it dosent work with PPPoE & WebProxy
how i can make it work with this
I Haven’t tested WEBPROXY with PCC,
But with PPPoE you have to modify some rules.
View following links to get some ideas.
http://forum.mikrotik.com/t/pcc-and-pppoe-server/34425/1
http://forum.mikrotik.com/t/problem-pcc-balance-pppoe-server/47788/16
for webproxy, you should mangle not only in prerouting, but also in output to balance Proxy’s traffic
