Hi all.
I have some issue with mesh. What I am doing exactly: I want to make roaming for office wifi users. I have 5 APs mikrotik 952U 5ac2ND , in future it will be 9APs.
I connect APs each to each - there 4 connection on AP - via EoIP. I use 172.16.255.0/24 network
Then I creating mesh interface and adding port, port is a EoIP
But on some stages of adding ports to mesh interface I get 100%load on EoIP and 100%CPU load.
EoIP name like ap1-ap6 and so on. Picture from Winbox
I’m deactivate mesh port “ap1-ap8” and after 10-20 secs - all going to normalized. load on CPU and EoIP goes down Picture from Winbox
Now all APs, except two APs - this APs use 5Ghz connection to others, connected via cable. I found this document where used EoIP and APs connected via cable to create roaming, so I try to repeat. May bee I should try to do “roaming” based on access list and signal strenght ?
You don’t need to do anything special. WiFi roaming is a function of client, not AP. I recommend reading a couple of great posts on the topic: first, second.
And I do not recommend kicking off clients based on signal strength to force them roam- this usually makes roaming experience worse.
From my experience, the best roaming results can be achieved when using CAPsMAN with local forwarding turned off.
