Mesh Internet Connection not working
Hello!
I want to make a mesh network for a school project with some hAP ac lite routers.
I want one router to be connected to the ethernet network and the other routers should connect wirelessly to each other so I can go to the internet via wifi from every router.
My problem is that the routers (except the one which is connected to the ethernet network) does not get an internet connection (ping says no route to host). But all routers are connected via wds. I can ping all of them via the local ip address.
What is my mistake to get it to work?
Thank you in advance :smiley: !
