MESH - KERNEL FAILURE
What follows in my first post refers to my first (a-bit-disappointing) MESH configuration attempt.
Using:
three RB433AH with ROS3.19, one of them as a mesh-portal, each one of them having:
an R5H card in ap-bridge mode to form the wds/mesh links
an R52 card (disabled for the moment)
one mesh interface named “TEST-MESH”)
dynamic WDS association to the mesh interface, and
one VLAN mesh sub-interface in order to access it from a specific subnet (irrelevant?)
It seems to work … in a “don’t touch it” mode:
When I try to change some wireless characteristics (e.g Tx Power) on the R5H card, the board reboots with a kernel failure with the attempted change never applied
log: jan/01/2002 03:00:12 system,error,critical System rebooted because of kernel failure
This doesn’t happen to the mesh-portal which of course has the ether1 as an alive (connected) mesh-port, although the wds links disruption produces the failure to the other two boards!!!
Interestingly enough, after the failure when checking on the firmware in use, I see:
routerboard: yes
model: “433AH”
serial-number: “1A7801E02CB8”
current-firmware: “”
upgrade-firmware: “2.18”
Using the wireless-test package and upgrading to v3.20 didn’t make any difference …
My next step is to verify that the failure is related exclusively to the MESH configuration.
Then I’ll check with a ubiquiti card
Then I will try to see if this happens with static wds
Then … I will use your precious help … if any :slight_smile:
Thanks.
i am having the same problem although i didnt look so deep but my boards are rebooting when changing 1 unit it seems to kill the others and this isnt good maybe the new software version will fix it i keep looking for it
