mesh single radio routing problem
I have built a single radio mesh network using HWMP.
I am capable of pinging any Access Point of the Wireless Distribution System, using the tools provided by the router, from Winbox.
Then, I add a client (my laptop) that receives a connection from one of the APs.
From the client, I am able to ping the AP that gave the connection.
However, I am not able to ping any of the other APs.
Do you have an idea of what is happening ?
Thanks for your help.
Best regards,
Javier Revilla
Zurich
Ps. Here you have the configuration of my radio card, of the mesh and of the IP addresses.
/interface wireless print
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:65:BB:25 arp=enabled
interface-type=Atheros 11N mode=ap-bridge
ssid="mesh_wisubi_bg" frequency=2467 band=2ghz-b/g
channel-width=20mhz scan-list=default
wireless-protocol=802.11 wds-mode=dynamic-mesh
wds-default-bridge=mesh1 wds-ignore-ssid=no
bridge-mode=enabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
compression=no
/interface mesh port print
Flags: X - disabled, I - inactive, D - dynamic
INTERFACE MESH
0 wlan2 mesh2
1 wlan1 mesh1
2 ether3 mesh2
5 D 12.1 mesh2
6 D 11.1 mesh1
/ip address print
ADDRESS NETWORK INTERFACE
0 X 192.168.1.8/24 192.168.1.0 ether1
1 X 192.168.3.8/24 192.168.3.0 ether3
2 X 192.168.11.8/24 192.168.11.0 wlan1
3 192.168.12.8/24 192.168.12.0 wlan2
4 192.168.11.8/24 192.168.11.0 mesh1
