I’m currently using Engenius M8000 APs for there meshing ability, 2.4ghz for client access and 5ghz for backhaul. I have two new sites to install with around 8 AP’s on each site and would like to use Mikrotik, but I’m not sure if the meshing would be similar.
Also, is it possible to use the RB433AH board with three wireless cards.. One 5ghz for the mesh backhaul, and two 2.4ghz for client access using directional antennas.?
Thanks for any advice in advance.
