My Message column in Log windows somehow vanished. Ne mater if I tick and un-tick 1000 times and login and logout I cant bring it back.
Version on WinBox is 3.27.
It behaved strange when I resize it the other day. Maybe there is some config file or regex value that I could bring back width or coordinates if it is out of range?
Appreciate any hint!
Thanks bpwl on your replay, but that post didn’t help. I cleared the cache many times and… nothing.
But what did help is that I cleared complete folder “**c:\Users<user>\AppData\Roaming\Mikrotik\Winbox**”. Maybe it would be enough to just delete c:\Users<user>\AppData\Roaming\Mikrotik\Winbox\settings.cfg.viw, but that I’ll try some other time.
Had run into the same problem. It is perfecly sufficient to delete c:\Users<user>\AppData\Roaming\Mikrotik\Winbox\sessions<IP address>.viw to drop damaged session file.
