Messed vlans - not routing
Latelly I tried to divide my network into vlans. After a lot of struggling I cannot make my vlans work correctlly. Wifi vlan in capsman is working but have issues with one on physical port:
2011UiAS (fw) –ether4(vlan id:2)– tp-link switch ------ server
Intefaces:
add fast-forward=no name=bridge-appliances
add fast-forward=no name=bridge-guest
add fast-forward=no name=bridge-iot
add fast-forward=no name=bridge-trunk
add fast-forward=no name=bridge-wlan
add admin-mac=E4:8D:8C:1D:0D:45 auto-mac=no comment=defconf fast-forward=no name=bridge1
add fast-forward=no name=ovpn-bridge protocol-mode=none
add fast-forward=no name=trunk-appliances
add fast-forward=no name=wlan-appliances-bridge1 protocol-mode=stp
add fast-forward=no name=wlan-bridge1 protocol-mode=stp
add fast-forward=no name=wlan-guest-bridge1
set [ find default-name=ether1 ] comment="Fiber device / INTERNET"
set [ find default-name=ether2 ] comment="IDS mirror of ether3" name=ether2-master
set [ find default-name=ether3 ] comment=switch
set [ find default-name=ether4 ] comment=trunk
set [ find default-name=ether5 ] comment=ap_gora
set [ find default-name=ether6 ] name=ether6-master
set [ find default-name=ether7 ] comment=gw_lte
set [ find default-name=ether8 ] comment=ap_piwnica
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] comment="ap_ogr\F3d"
/interface vlan
add interface=ether5 name=vlan-ap_gora vlan-id=6
add interface=wlan-appliances-bridge1 name=vlan-appliances vlan-id=6
add interface=wlan-guest-bridge1 name=vlan-guest vlan-id=20
add interface=wlan-appliances-bridge1 name=vlan-iot vlan-id=12
add interface=ether4 name=vlan-trunk-appliances vlan-id=6
add interface=ether4 name=vlan-trunk-servers vlan-id=2
add interface=wlan-bridge1 name=vlan-wlan vlan-id=11
/interface ethernet switch
set 0 mirror-source=ether3 mirror-target=ether2-master
set 1 mirror-source=ether7 mirror-target=ether6-master
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add bridge=bridge1 comment=defconf interface=ether2-master
add bridge=bridge1 comment=defconf interface=ether6-master
add bridge=bridge1 comment=defconf hw=no interface=sfp1
add bridge=bridge1 disabled=yes interface=ether1
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge-appliances interface=vlan-appliances
add bridge=bridge-iot interface=vlan-iot
add bridge=bridge-appliances interface=vlan-ap_gora
add bridge=bridge-wlan interface=vlan-wlan
add bridge=bridge-guest interface=vlan-guest
/interface bridge settings
set use-ip-firewall=yes
add interface=sfp1 list=discover
add interface=ether2-master list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=ether6-master list=discover
add interface=ether7 list=discover
add interface=ether8 list=discover
add interface=ether9 list=discover
add interface=ether10 list=discover
add interface=bridge1 list=discover
add interface=wlan-bridge1 list=discover
add interface=wlan-guest-bridge1 list=discover
add interface=wlan-appliances-bridge1 list=discover
add interface=ovpn-bridge list=discover
add interface=bridge1 list=mactel
add interface=bridge1 list=mac-winbox
Firewall:
/ip firewall address-list
add list=Blocked
add action=drop chain=input comment="Suricata: Block bad actors" src-address-list=Blocked
add action=drop chain=forward comment="Drop any traffic going to bad actors based on Suricata" \
    dst-address-list=Blocked
add action=add-dst-to-address-list address-list=test-facebook address-list-timeout=1m chain=\
    forward comment=Test content=*facebook.com disabled=yes protocol=tcp src-address=\
    192.168.1.0/24
add action=drop chain=forward comment="Isolate guest wlan" in-interface=bridge-guest \
    out-interface=!ether1
add action=drop chain=forward comment="Isolate guest wlan" in-interface=!ether1 out-interface=\
    bridge-guest
add action=accept chain=input comment="defconf: accept establieshed,related" connection-state=\
    established,related
add action=accept chain=input dst-port=1194 protocol=tcp
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=ether1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
    established,related
add action=drop chain=forward disabled=yes in-interface=bridge-appliances out-interface=\
    bridge-iot
add action=accept chain=forward comment="defconf: accept established,related" connection-state=\
    established,related
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface=ether1
add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.1.0/24
add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.2.0/24
add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.9.0/24
add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.20.0/24
add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.12.0/24
add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.11.0/24
add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.10.0/24
add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.6.0/24
add action=dst-nat chain=dstnat dst-port=443 in-interface=ether1 protocol=tcp to-addresses=\
    192.168.1.100 to-ports=443
add action=dst-nat chain=dstnat dst-port=22 in-interface=ether1 protocol=tcp to-addresses=\
    192.168.1.100 to-ports=22
The weird thing is that server is visible to firewall and gets its dhcp ip in vlan subnet but it cannot communicate with othes bridges. I can even ping it from vlan-trunk-servers. I tried several how-tos, with vlan interface in bridge and without them. What am I missing?
Ok, to make It simpler.
I have bridge1 (bridged all ports but ether4) and have vlan-trunk on ether4. What should I do to be able to communicate between bridge1 and clients on vlan-trunk. Swich connected to trunk seems to be configured ok as I can see vlan tag on ether4 torch.
Take a look on this configuration example.
Tried that one. No luck. Even worse :confused:
I also tried to make bridge vlan filtering. Got better results, but again - got 2 bridges - bridge trunk with one port and bridge1 with rest of ports. Unfortunatelly I could not communicate between them.
The worst thing is that if I enable bridge vlan filtering on my production configuration than the device freezes and looses all interfaces in winbox. I have to restart it, but after restart vlan filtering is disabled.
Bought some test equipment - will try to figure it out on them instead of messing out production.
After simplifying my network Infrastructure I managed to accomplish what I intended:
                                       untagged clients
router   <--- trunk --->   switch   -  tagged clients
                                        capsman, caps
Everything is created in /interface vlan and working almost ok. One last issue to resolve is flapping of some interfaces. This is found mainly on two caps connected directly to switch and one untagged client. Can it be related to rstp turned on? Should I disable all stp as it is not working anyway in this config anyway?
EDIT: In capsman logs I get:
removing stale connection […] because of ident conflict with […] every couple minutes.
