Messenger, Facebook (Texas Holdem Poker) Skype problem
i have read a topic for this problem but it didnt work. Is there any way to route traffic from messenger and specific addresses to a specific gateway?
i have two adsl lines, both of them with adsl routers and both of the routers connected to mikrotik in load balance. Everything works fine,except these services that keep disconnecting. Is there a way to route the right way and solve the problem?
yes, use policy routing..
M.
Hi ErmalT, i have the same setup as yours.. with 2 adsl routers..can you please explain to me how to configure load balancing ? please tell me which manual did you refer ?
Thankyou
please guide me to the article i need to follow to creat load balancing and fail over incase of 1 ADSL router fails.
Cheers
http://wiki.mikrotik.com/wiki/Load_Balancing_Persistent
this was the easest one. it worked perfectly.
can you give me some hints on where to start from?
i have two wan connections 192.168.1.0/24 and 192.168.2.0/24 with gateways 1.254 and 2.254
i have two rules in farewall with masquerade for each of the connections but messenger keeps disconnecting, facebook with live games also. for all the other things everything works fine
Damn that was easy.. thanks alot..
