Private Only - (Real OS acting) Mikrotik RB450G ↔ Ubiquiti Devices Acting As Bridges ↔ CPE = Router Mode on the ubiquiti units …
Public (MetaRouter) - Routed IP’s …
Ether1 = public ip network
Ether5 = private ip network
I set interfaces up on the MetaRouter to Ether1 and Ether5, go and assign addresses to only have the entire unit cold-restart. (Crashes)
I have 4 in service right now and all appear to result with the same thing …
I am curious if anyone else is having this issue, support w/ Mikrotik after even sending them the sup files have not been helpful and I have given them the same scenario described above.
If it is not enough information please let me know.
Assuming you are running the latest software (5.15) and RouterBOOT (2.39? ‘/system routerboard upgrade’) – and, if you’ve been talking to support, hopefully you are – then please check to see what the voltage output is on your power supply that you are using with your 450G. If it is greater than 12v, please switch to a 12v power supply. Report back here with your results.
