hi everybody
can i configure the metal device as a repeater ?
if yes… How?
regards
In wds mesh with other mikrotik device as other wds side.
Sent from Android by Tapatalk.
Such as Jarda said.
Mikrotik devices can no signal from other brand Repeaten.
http://wiki.mikrotik.com/wiki/Wireless_repeater
Dear Mr. Plisken
can you please guide me stip by stip ?
i read the link http://wiki.mikrotik.com/wiki/Wireless_repeater
but i couldn’t do any thing.
regards
What devices do you have, what did you set and what does not work?
Dear Mr. Plisken
i have metal2 in my network as access point , and i wont to extend the covered area by
using another metal.
please i could’t understand English scripts so i need stip by stip graphic explanation if you can.
thanks a lot for replay
regards
If the link to official WDS guide is too much complicated for you, try to have a look at this:
http://sujianto.files.wordpress.com/2008/05/how-do-i-set-up-wds-using-mikrotik.pdf
It is quite old but shows the screens with explanations.
Also check this one, it looks pretty good and is more recent:
http://harry.subnetworx.de/2014/02/21/routeros-wds-repeater-configuration-guide/
Did you even try to google:
https://www.google.cz/search?num=100&newwindow=1&safe=off&site=&source=hp&q=mikrotik+wds+step+by+step&oq=mikrotik+wds+step-by&gs_l=hp.3.0.0i22i30.1945.6581.0.8393.21.17.0.2.2.0.1008.3526.3j11j1j1j7-1.17.0....0...1c.1.40.hp..6.15.1901.0.aLMFz962Z0E?
Now you have to try yourself.
Anyway, remember that the best “wireless” link is only with wire.
So, do as much as possible to connect additional AP by wire instead of using WDS. Or at least use PtP bridge. It costs 3times more then adding one device to WDS, but will provide speed and reliability of the connection. WDS is always a trade-off.
