The other day I couldn’t connect at all and couldn’t even ping the device. I took it down from the pole to try and connect to it from inside.
I noticed that the metal 2shpn doesn’t power on at all. When i connect the poe , the power light turns green and then immediately turns off.
Is the ethernet port burned? Is the metal fried? Have this happened to any of you guys?
Is there any way i can connect with the device? Any tips or advice to repair it or something, would be really appreciated
Did you have it connected with STP cable AND using a Ethernet lightning suppressor that were both properly grounded? If not, they are easily damaged by ESD.
