Metal 2SHPn to 951-22n
Hello - I am very new to Mikrotik and have a n00b question.
I live in a marina with many sailboats and masts, so my pc/roku boxes have a hard time connecting to the marinas wifi network. After doing some basic research I purchased a 951 and 2HSPn to get a better connection.
I have the 2HSPn on deck to connect to the marina’s wifi network. The 951 is below deck to run a local wifi network for devices to connect to.
I have managed to get the 2SHPn to connect to the marinas wifi network, but I am getting confused on how to connect it to the 951. Do I use it as a Bridge or AP or CPE in the quick connect screen?
Any help would be great!
Jason
Use as bridge with DHCP-client on de bridge
thank you, that worked.
i set the metal as a bridge with dhcp and the 951 getting its addresses from the metal.
wifi is working. however, it seems to be a bit slower than i expected.
is there a better way to do this setup, do i need any routing or addition settings?
Can you paste your export result from metal and rb?
Go to new terminal.
Type export and paste the result here on this forum.
