Metal 52 ac and CAPSMAN
Hello all,
I have a CAPSMAN based wireless network at home consisting of four WAP AC and one Metal 52 ac.
One WAP AC is the CAPSMAN and the others are CAPs.
I have one 2,4GHz SSID and two 5GHz SSIDs up and running.
Everything is working as expected, only the Metal 52 ac is not.
The Metal 52 ac can be used either in 2,4GHz or in 5GHz mode.
Per default the Metal 52 ac gets provisioned with the 2,4GHz SSID, but I want it to be provisioned with the two 5GHz SSIDs.
How can I change the mode of the Metal 52 ac?
Thank you very much,
Albert
For ohne device i would set an Provisioning Mac based for the Metal in caps konfig,
Then you Fan choose the Profile you Need for the Metal
Thank’s mistry7,
it’s working now!
