OK, easy to calculate:
9dBm from Metal + 21 from Antenna =30 dBm = 1W
Path:
TX Side: 30dBm - Path Loss for 11,5km at 5600 (-128 db) = -98
RX Side: -98 Path Loss + 21 dBi Antenna = -77 dBm at the Metal52
Without any margin you would stay at
MCS 3 or 4 that means 28,9 or 43,3MBit with 1 Stream
Could be hard to get 10MBit stable with 20Mhz Channel
LHG:
RX Side LHG = -98 + 25 LHG = -76 dBm at LHG
MCS 12 or 13 that means 86,7 or 115,6MBit with 2 Stream
No problem for 10 MBit
Path:
TX Side: 30dBm - Path Loss for 1km at 5600 (-107 db) = -77 dB
RX Side: -77 dB Path Loss + 21 dBi Antenna = -56 dBm at the Metal52
You get 72,2 MBit at 20 MHz
SXT
Path:
RX Side: -77 dB Path Loss + 16 dBi Antenna = -61 dBm at the SXT5 ac
You get 173,3 MBit at 20 MHz
I would go with LHG and SXT not with old 1 Pol Antenna!
