Metal 52 Virtual AP
Hello
I am trying to create 2 access points in my metal 52. After reading several posts and tutorials I arrived at this configuration, but without any results. Is there anyone here who can help me?
What am I doing wrong or what do I need to do more?
# apr/07/2020 17:23:59 by RouterOS 6.46.4
# software id = KT9S-5YPH
# model = RBMetalG-52SHPacn
# serial number = B7D90B0F83A4
add name=BR1 protocol-mode=none vlan-filtering=yes
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-eC \
    country=no_country_set disabled=no frequency=auto frequency-mode=\
    superchannel installation=outdoor mode=ap-bridge ssid=AG_NETWORK
/interface vlan
add interface=BR1 name=AG_VLAN vlan-id=2
add interface=BR1 name=BASE_VLAN vlan-id=99
add interface=BR1 name=LM_VLAN vlan-id=101
add interface=BR1 name=SSL_VLAN vlan-id=10
add name=WAN
add name=LAN
add name=BASE
add name=VLAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    mode=dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    management-protection=allowed mode=dynamic-keys name=ssl \
    supplicant-identity=""
    management-protection=allowed mode=dynamic-keys name=lm44 \
/interface wireless
add disabled=no keepalive-frames=disabled mac-address=C6:AD:34:26:59:1F \
    master-interface=wlan1 multicast-buffering=disabled name=wlan2 \
    security-profile=ssl ssid=SSL_NETWORK wds-cost-range=0 wds-default-cost=0 \
    wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=C6:AD:34:26:59:20 \
    master-interface=wlan1 multicast-buffering=disabled name=wlan3 \
    security-profile=lm44 ssid=LM44_NETWORK wds-cost-range=0 \
    wds-default-cost=0 wps-mode=disabled
/ip hotspot profile
add name=AG_POOL ranges=192.168.1.2-192.168.1.254
add name=SSL_POOL ranges=192.168.2.2-192.168.2.254
add name=LM_POOL ranges=10.101.1.41-10.101.1.50
add name=BASE_POOL ranges=192.168.0.10-192.168.0.254
add address-pool=AG_POOL disabled=no interface=AG_VLAN name=AG_DHCP
add address-pool=SSL_POOL disabled=no interface=SSL_VLAN name=SSL_DHCP
add address-pool=LM_POOL disabled=no interface=LM_VLAN name=LM_DHCP
add address-pool=BASE_POOL disabled=no interface=BASE_VLAN name=BASE_DHCP
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged \
    ingress-filtering=yes interface=wlan1 pvid=2
add bridge=BR1 ingress-filtering=yes interface=wlan2 pvid=10
    ingress-filtering=yes interface=wlan3 pvid=101
add bridge=BR1 frame-types=admit-only-vlan-tagged ingress-filtering=yes \
    interface=ether1
set discover-interface-list=BASE
/interface bridge vlan
add bridge=BR1 untagged=wlan1 vlan-ids=2
add bridge=BR1 untagged=wlan2 vlan-ids=10
add bridge=BR1 untagged=wlan3 vlan-ids=101
add bridge=BR1 tagged=BR1,ether1 vlan-ids=99
add interface=ether1 list=WAN
add interface=BASE_VLAN list=BASE
add interface=BASE_VLAN list=VLAN
add interface=AG_VLAN list=VLAN
add interface=SSL_VLAN list=VLAN
add interface=LM_VLAN list=VLAN
add address=192.168.0.3/24 interface=BASE_VLAN network=192.168.0.0
add address=192.168.1.1/24 interface=AG_VLAN network=192.168.1.0
add address=192.168.2.1/24 interface=SSL_VLAN network=192.168.2.0
add address=10.101.1.40/24 interface=LM_VLAN network=10.101.1.0
add address=10.101.1.0/24 dns-server=192.168.0.1 gateway=10.101.1.40
add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1
add address=192.168.1.0/24 dns-server=192.168.0.1 gateway=192.168.1.1
add address=192.168.2.0/24 dns-server=192.168.0.1 gateway=192.168.2.1
add action=accept chain=input comment="Allow Estab & Related" \
add action=accept chain=input comment="Allow Base_Vlan Full Access" \
    in-interface=BASE_VLAN
add action=drop chain=input comment=Drop
add action=accept chain=forward comment="Allow Estab & Related" \
add action=accept chain=forward comment="VLAN Internet Access only" \
    connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=drop chain=forward comment=Drop
add distance=1 gateway=192.168.0.1
/system clock
set time-zone-name=Europe/Lisbon
/system identity
set name=SSL_FOH_AP
/tool mac-server
set allowed-interface-list=BASE
/tool mac-server mac-winbox
Metal 52 has a selectable band either 2.4 OR 5.0 GHz band…
Now, in case you want to create a virtual AP, just click the plus sign on your wireless tab, click virtual, at the second tab set mode as AP bridge, set SSID and the security profile. All the rest will be taken from the Master Interface… as simple as that…
Yes, i know how to setup basic configurations.
What about vlans? How do i setup vlans ?
But nothing in your config shows any virtual AP !!!
Unless i missed it…
What about VLANs? Your question is so general…
A nice article here http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1
Unless i missed it…
They are there:
wlan1=Master interface ssid=AG_NETWORK
wlan2=Virtual AP ssid=SSL_NETWORK
wlan3=Virtual AP ssid=LM44_NETWORK
A nice article here viewtopic.php?f=13&t=143620
This configuration was created based on that article
I have 3 sets of gear i wich to remote control with a single Metal52
Amplifiers: VLAN2; Subnet 192.168.1.0; wlan1
Mixing console: VLAN10; Subnet 192.168.2.0; wlan2
System Processor; VLAN101; Subnet 10.101.1.0; wlan3
All the gear is connected to a switch, with the VLANS configured. There is also a trhruk port conneting the switch to Metal52
In the section /interface bridge vlan you have to add bridge interface (BR1) as tagged member to all VLANs where router has IP address set (via vlan interfaces created in /interface vlan). In the posted config it’s done only for VLAN 99, but should be done for all the rest as well (or else wlan-connected devices can not talk even to DHCP servers configured on respective vlan interfaces). And similarly for ether1 … you’re saying it’s a trunk port so it shoukd be tagged member of all VLANs it’s supposed to pass.
@JPMARTINS i missed it :laughing:
As for the VLANs i would strongly suggest you read the article i posted earlier… It is not about doing something but we must know why we do it…!
Tue Apr 07, 2020 9:20 pm
BR,
Metod
I notice that and i have it corrected
# apr/07/2020 17:59:40 by RouterOS 6.46.4
/interface wireless
set [ find default-name=wlan1 ] ampdu-priorities=0,1,2,3,4,5,6,7 band=\
    2ghz-b/g/n channel-width=20/40mhz-eC country=no_country_set disabled=no \
    frequency=auto frequency-mode=superchannel installation=outdoor mode=\
/interface vlan
add name=WAN
add name=LAN
add name=BASE
add name=VLAN
/interface wireless
    security-profile=ssl ssid=SSL_NETWORK vlan-id=10 wds-cost-range=0 \
    security-profile=lm44 ssid=LM44_NETWORK vlan-id=101 wds-cost-range=0 \
/ip hotspot profile
add add-arp=yes address-pool=SSL_POOL disabled=no interface=SSL_VLAN name=\
    SSL_DHCP
/interface bridge filter
add action=drop chain=input dst-port=68 in-interface=ether1 ip-protocol=udp \
    mac-protocol=ip
    interface=ether1
add bridge=BR1 tagged=BR1 untagged=wlan1 vlan-ids=2
add bridge=BR1 tagged=BR1 untagged=wlan2 vlan-ids=10
add bridge=BR1 tagged=BR1 untagged=wlan3 vlan-ids=101
add interface=wlan1 list=LAN
/ip dhcp-client
add disabled=no interface=BR1
add address=10.101.1.0/24 dns-none=yes gateway=10.101.1.40
add address=192.168.1.0/24 dns-none=yes gateway=192.168.1.1
add address=192.168.2.0/24 dns-none=yes gateway=192.168.2.1
    connection-state=established,related disabled=yes
add action=accept chain=input comment="Allow Base_Vlan Full Access" disabled=\
    yes in-interface=BASE_VLAN
add action=drop chain=input comment=Drop disabled=yes
    connection-state=new disabled=yes in-interface-list=VLAN \
add action=drop chain=forward comment=Drop disabled=yes
add disabled=yes distance=1 gateway=192.168.0.1
/system clock
/system identity
set name=SSL_FOH_AP
/system leds
set 1 leds=led1 type=interface-activity
add interface=wlan2 leds=led3 type=interface-activity
add interface=wlan3 leds=led5 type=interface-activity
/tool mac-server
I read the article and it was based on it that I created this configuration.
However, something is missing.
So I asked for help
wow you are fast… it took me days to read it and i still consult it from time to time…
This is something i´m working on a few days, based on that article
@JPMARTINS: I’ve re-read the whole thread … and I realized you never write what exactly seems to be the problem.
That’s true @mkx
Hi
The problem is that I can’t reach the gear connected in the switch.
Connecting my iPad to wlan2, I get up address from DHCP server in Vlan10, but the App can’t “see” the mixing console connect to the switch.
I seems that the wlans are working fine, since I get IP address from DHCP servers, but there’s something wrong in the bridge config because I can’t reach the gear connected to the switch.
The switch has the same VLANs. Trunk is on VLAN ID1.
VLAN ID2, 10 and 101 for audio gear
VLAN ID99 for management.
The only VLAN that is working is VLAN 99
Can you ping devices on different VLANs from the router itself?
Simply running /ping from terminal window will tell.
No. I can’t ping any devices.
All audio devices usually have static IP address and I’m no sure are getting up address from VLANs DHCP Server. Next Tuesday I will change them to DHCP.
Hello
I found that the VLANS were not configured correctly on the ETHER1 side.
Everything is working as I intend
