Metal and Mant30, best way?
Hi to all, I need to use Metal with Mant30.
I can find cable (N to RP SMA) on Amazon, but it is RG58, so I have 1dB/m of loss; I can’t find connectors to connect Mant30 blue cable (btw, which cable type is it?) to Metal.
What do you suggest?
Thanks.
This loss is for one meter, maybe find a shorter cable, or maybe a direct adapter:
https://www.amazon.com/onelinkmore-Adapter-Connectors-Adaptor-Connector/dp/B06XPDWBPR/ref=sr_1_13?keywords=rp%2Bsma%2Bto%2Bn&qid=1576244047&sr=8-13&th=1
