Metal did not plug into switch
Hi
I want to setup a link with metal,when i plug it into my laptop ,it’s ok but port is down when plug it into cisco switch
i tested different switch and port and i am sure that is not switch problem
I have another metal link that works properly
thanks for your help
Have you tried switching out your cable?
yeah,i change my cable and connectors but nothing happened
also testing cross cable , upgrade router os and …
make sure you are powering the Metal with PoE injector, it will not accept power from PoE switches.
