Metal PtP link problem
Hello, folks.
I have a clear nice link about 3 km with relatively clean spectrum.
The problem is that 2 metals with 34 dbi grid antennas could not establish a connection.
Here comes configs
  1. Point 1
#RouterOS 6.27
# software id = PR4E-XTZT
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n channel-width=20/40mhz-ht-below \
    disabled=no frequency=5350 frequency-mode=superchannel ht-guard-interval=\
    long hw-retries=15 l2mtu=2290 mode=station-bridge nv2-preshared-key=\
    12345678 nv2-security=enabled periodic-calibration=enabled scan-list=5350 \
    ssid=Z-K1 wireless-protocol=nv2-nstreme
/interface wireless nstreme
set wlan1 enable-nstreme=yes
/ip neighbor discovery
set wlan1 discover=no
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=12345678
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
/queue type
set 1 pfifo-limit=500
set 2 kind=pfifo pfifo-limit=500
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add bridge=bridge1 interface=wlan1
set enabled=no
add address=10.255.245.218/29 interface=bridge1 network=10.255.245.216
add distance=1 gateway=10.255.245.217
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system identity
set name=Zanzibar
/system leds
set 0 interface=wlan1 leds=led1,led2,led3,led4,led5 type=\
    wireless-signal-strength
set 1 interface=ether1 leds=user-led type=interface-activity
/system logging
add topics=wireless
  1. Point 2
#  by RouterOS 6.27
# software id = HKYG-A1GV
add name=bridge1
/interface wireless
    long hw-retries=15 l2mtu=2290 mode=bridge multicast-helper=disabled \
    nv2-cell-radius=10 nv2-preshared-key=12345678 nv2-security=enabled \
    periodic-calibration=enabled scan-list=5350 ssid=Z-K1 wireless-protocol=\
    nv2-nstreme
/ip ipsec proposal
/queue type
set enabled=no
add address=10.255.245.219/29 interface=bridge1 network=10.255.245.216
add address=10.255.243.54/30 interface=bridge1 network=10.255.243.52
add distance=1 gateway=10.255.243.53
/ip service
/system clock
set time-zone-name=Europe/Tallinn
/system identity
set name=K1-Z
/system leds
/system logging
add topics=wireless,debug
On Point1 logs I see
19:46:45 wireless,debug 4C:5E:0C:83:E3:03: on 5350 AP: no SSID Z-K1 caps 0x0 rates 0x0 basic 0x0 MT: n
o
19:46:45 wireless,debug wlan1: 4C:5E:0C:83:E3:03 failed to join recently
19:46:45 wireless,debug wlan1: no network that satisfies connect-list,  by default choose with stronge
st signal
19:46:45 wireless,debug wlan1: 4C:5E:0C:83:E3:03 uses TDMA, skip
st signal
19:46:45 wireless,debug wlan1: failed to select network
19:46:45 wireless,debug wlan1: delaying scanning
19:46:48 wireless,debug wlan1: must select network
I tried different frequencies, wireless/wireless-fp packages, different power levels - same issue.
Any suggestions ?
RGDS
D.
Disable security and set channel to auto on AP, default on station. If is it working you have an starting point of discover your mistake.
Btw verify this: connect-list, better disable it.
Connect-list is empty.
Same problem with disabled security.
Reset configuration with no defaults. Then rebuild.
