Metal5 SHPN association problem
Hi everyone
i have a 54KM LOS with Metal5 SHPN and 32dbi dish over sea , in client side i receive -60 db signal strength , but i can not connect , debug log show me association error !
what’s this error ? it means my signal is poor ? and what the solution
thank you :slight_smile:
First:
try disable security on both sides
security is disabled
before installation i’ve test them , and client connected to the AP easily , but after installation i got this error
print wireless settings
hi
i solved association error but i got new problem ! ranging timeout
i’m using nv2 protocol, i think i should change 30 km default value , am i right ?
How you solved this problem?
30km is default value. Minimum is 10km. You can change it
i was about default authentication checkbox !
