How can I have MetaRouter assigned an IP in a VLAN attached to Ether2 ?
Until now I have used a bridge between this vlan and the virtual interface with DHCP server targeting the bridge.
Is there a way to get rid off the bridge and have MetaRouter request an IP on ether2 with eth0.100 declared in OpenWRT or directly on vlan interface with regular eth0 ?
Tried both and I was unsuccessful.
If I want my MetaRouter to have an IP in a range that is declared on the Mikrotik, is it only possible using a bridge between the virtual interface and another interface on the Mikrotik corresponding to IP range ?
If I want to assign my MetaRouter Virtual Ethernet an IP in one of the ranges declared on the Mikrotik, how would I do it ?
I tried to assign the VIF itself an IP manually (IP > Addresses) and manually configured one in the same range on OpenWRT with no luck.
in this case throw all the virtual stuff out of the equation and think in terms of independent devices and physical interfaces.
so, if you have interface with attached Ethernet network to it, and you have another interface on another device that you want to be part of the same Ethernet network but is connected to another interface of the router - you have to bridge 2 router interfaces to extend the Ethernet network to that extra interface on another device.
That’s what I have done so far but now I also need IGMP Proxy / PIM on this bridge because vlan100 contains printers, etc.
But in an exchange we had on support@ you told me bridges can’t be used in PIM. I’m trying to find a solution…
if you have to extend ethernet, there is no other option but bridge. If you can have different network address, then you can use igmp-proxy and routing to access these devices
ok then, where are the multicast sources, where are multicast destinations? What groups are used and is source part of network that your router interface receiving it?
Sources are in vlan100 - 10.1.0.0/25 (printers, NAS, etc. - all emitting Bonjour frames)
Receivers are in vlan200 - 10.2.0.0/24 (laptops, phone, etc.)
To be able to answer, can you tell me what you are expecting (which tab or /routing print would you need ?)
Cause I configured RP with group 224.0.0.0/4 which I thought would cover all groups.
Yes both the vlans and RP are on the same router (the Mikrotik).
if you sniff packets on incoming (underlying) interface are they correctly tagged, are there join in /routing pim joins
is there relevant entries in /routing igmp-proxy mfc (this is only place to see MFC entries, for everything else do not mix pim and igmp-proxy configurations)
I can see igmp packages travelling on vlan100 to 224.x.x.x IPs - Those IPs I can see them in PIM/IGMP Groups.
In PIM/Joins I have:
group 224.0.0.0, source 10.1.0.1, RP 10.1.0.1, not joined, join register state unknown
group 239.255.255.250, source 10.1.0.30, RP 10.1.0.1, joined, join register state unknown
group 239.255.255.250, source 0.0.0.0, RP 10.1.0.1, joined, join register state unknown
DA, group 239.255.255.250, source 10.1.0.30, upstream interface unknown, downstream interface , packets 1166
10.1.0.30 is the NAS, I never saw frames coming from the printer, that’s a second strange thing.
