Metarouter images
liquidcz, is it possible to do the same with newer release of OpenWRT?
I would like to, but there is a problem with mikrotik patch and openwrt with different kernel version.
I cant get ppc version running on RB800 … mipsbe runs fine on my rb493.
JF
Any error messages or detailed description? I’m unable to test PPC because I dont have any PPC hardware.
Great work! Thanks. But it looks like there is no “asterisk-gui” in package repository. It would be great if someone could build one.
there is a problem on PPC hardware regarding OpenWRT - guest is not booting. So that is an issue on our side.
As I remember this is an old issue, still not fixed.
janisk: Thank you for that information.
unfortunately this is not as trivial as it might seem.
How about Metarouter on Multi-core? Does any body have latest news?
I don’t want to appear impolite, but I’ll question one more time-is there any way of getting any kind of webif for asterisk on backfire? It seems like there is no package asterisk-gui in repository. Package from kamikaze gives me an error-incorrect architecture. I really need it. Thank you.
As janisk reported it does not boot, no error messages, nothing, just CPU goes up to 100% and stays there. I have tested on rb800 with ros 6.10 … mipsbe version is running great for days now on my rb493g … great work, tnx!
JF
I just updated my repositories and include asterisk-gui.
I just create new “experimental” repositories for Attitude Adjustment 12.09 build 36088 + ALL packages + Asterisk GUI.
OpenWrt milestone info: https://dev.openwrt.org/milestone/Attitude%20Adjustment%2012.09
Modifications:
  • Experimental MetaRouter Patch for Kernel 3.3.8
  • changed root password to: master
  • changed eth0 to DHCP
  • changed opkg source to my repositories
MIPS:
http://openwrt.wk.cz/attitude_adjustment/mr-mips/openwrt-mr-mips-rootfs.tar.gz
CONFIG MIPS:
http://openwrt.wk.cz/attitude_adjustment/mr-mips/config-mips-aa-36088-20140311
PACKAGES:
http://openwrt.wk.cz/attitude_adjustment/mr-mips/packages/
PPC:
http://openwrt.wk.cz/attitude_adjustment/mr-ppc/openwrt-mr-ppc-rootfs.tar.gz
CONFIG PPC:
http://openwrt.wk.cz/attitude_adjustment/mr-ppc/config-ppc-aa-36088-20140311
PACKAGES:
http://openwrt.wk.cz/attitude_adjustment/mr-ppc/packages/
Enjoy!
For me everything is working perfect! Thank You!!! Build 36088 is now my gold standard. :smiley:
Great news! Works great for me with samba 36.
But it looks like there are some dependencies problems for asterisk gui (asterisk18-res-phoneprov, asterisk18-app-meetme and asterisk18-app-page)
Anyway, this is unbelievably cool! Thanks.
liquidcz
Thanx for builds. I have try last build for mips and something go strange.
My rb951 have 5 ethernets.
ether1 for my isp
etrer2-5 for my local devices.
I have no bridges.
When i import image into metarouter, it was started corectly, but dhcp-client dont work. And i see droped packeges
root@metarouter:/# ifconfig
eth0      Link encap:Ethernet  HWaddr 02:97:24:54:0D:20
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:399 errors:0 dropped:115 overruns:0 frame:0
          TX packets:79 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:27692 (27.0 KiB)  TX bytes:31205 (30.4 KiB)
I try to set up VM interface to ether1 port(my isp) and VM get IP. No droped packets and so on.
What i do wrong?
[admin@MikroTik] /metarouter> export
# mar/14/2014 15:38:57 by RouterOS 6.11rc1
# software id = 2BME-LLFU
/metarouter
add name=mr1
/metarouter interface
add static-interface=ether2-master-local virtual-machine=mr1 vm-mac-address=\
    02:97:24:54:0D:20
[admin@MikroTik] /ip dhcp-server> export
# mar/14/2014 15:37:28 by RouterOS 6.11rc1
add add-arp=yes address-pool=default-dhcp disabled=no interface=\
    ether2-master-local lease-time=1d name=home_network
I see, Im going to try to build these packages.
Lets try to use another (ether3,4,5) static interface for metarouter then ether2-master-local where DHCP server is binding.
liquidcz
I tried another ether, but my lan dhcp dont work. Work only on ether1. Metarouter catch ip from isp dhcp server. Pings and so on work perfect.
May be root of problem is droped packets in eth0 interface, how can i diagnostic why packets drop?
P.S. can you add nano text editor at next builds? vi not friendly for me…
