I am curious what the issue seems to be. Your own kernel can boot on PPC inside of Metarouter. Can’t MikroTik just share what is different about their kernel that allows it to work?
Some months ago, I tried to compare the 3.3.5 patches with the 2.6.35 patches and I couldn’t see any difference between the Metarouter guest code on those two versions. Maybe MikroTik doesn’t know why their kernel works but others don’t? Or maybe on PPC, it has something to do with changes outside of Metarouter in the Linux kernel, and if I built a 3.3.5 kernel with Metarouter support, it would also work?
Check your DHCP server: most likely there will be a red line mentioning that wrong interface is selected.
Choose your bridge instead of the ether interface.
Once changed it will work.
Typing reboot in console, removes the vif and creates a new one.
Using restart of metarouter does noting, machine is stuck. (disable, enable)
opkg install luci says there are missing dependencies?
I tried compiled image from http://openwrt.wk.cz/attitude_adjustment/mr-ppc/, but it’s not booting. Testing on RB1100AH, RouterOS 6.20, newest firmware.
Old images from your site (for example r31411) is working, but it’s not stable and I have a problem with some libraries.
What was changed between these releases, that don’t allow boot.
It looks like you have to switch to other repository or build image/packages yourself as it seems that either mirror is down or packages pulled, or packages has never been there.
Unfortunately failed to build , on attitude adjustment 12.09 as well as Barrier breaker 14.07 I am getting after a long waiting (make: *** [world] Error 1)
I used the Mikrotik openwrt-metarouter-1.2.patch patch
Before I executed the make menuconfig and make I ensured that nothing is missing by doing the following steps:
patch 1.2 is only for kamikaze, you have to use user created patch for attitude adjustment or have to create your own patch for releases after the attitude adjustment.
