METAROUTER + OPENWRT = OPKG ERROR IN RB433AH
I have installed openwrt with metarouter in a RB433AH, i used the precompiled version openwrt-mr-mips-rootfs.tgz.tar downloaded in mikrotik . I have internet access in openwrt. The problem is that:
in /etc/opkg.conf I have:
src/gz snapshots http://downloads.openwrt.org/snapshots/trunk/mr-mips/packages
dest root /
dest ram /tmp
lists_dir ext /var/opkg-lists
option overlay_root /overlay
thes link doesnt work, I tried those:
http://openwrt.pantele.com.ua/trunk/metarouter/packages
http://downloads.openwrt.org/snapshots/trunk/ar71xx/packages
http://downloads.openwrt.org/snapshots/trunk/atheros/packages
http://downloads.openwrt.org/snapshots/trunk/rb532/packages
they dont work, when I put opkg update, all the packeges say XX has no valid architecture, ignoring.
Any suggests?
thanks in advance
There is no official packages for metarouter on openwrt download site.
Read this topic http://forum.mikrotik.com/t/metarouter-images/28791/1
a, ok, I want to install asterisk, I sould compile by myself? I mean make, make install etc?
thanks in advance
either build them yourself or find on the internet. there are someone who did build them, just not sure that he/she have build with new patch and newer version of OpenWRT
I could’t find asterisk.ipk for metarouter for the rb433ah, so i tried to compile by myself, but when i try make asterisk I have an error, it seems that make is not installed, what can I do?:
/bin/ash: make: not found
here I show you mi installed packages:
root@OpenWrt:/usr/src/# opkg list-installed
base-files - 42-r20828
busybox - 1.16.1-2
dnsmasq - 2.52-2
dropbear - 0.52-4
firewall - 1-10
hotplug2 - 1.0-beta-1
iptables - 1.4.6-2
iptables-mod-conntrack - 1.4.6-2
iptables-mod-nat - 1.4.6-2
kernel - 2.6.31.10-1
kmod-crc-ccitt - 2.6.31.10-1
kmod-ipt-conntrack - 2.6.31.10-1
kmod-ipt-core - 2.6.31.10-1
kmod-ipt-nat - 2.6.31.10-1
kmod-ipt-nathelper - 2.6.31.10-1
kmod-ppp - 2.6.31.10-1
kmod-pppoe - 2.6.31.10-1
libc - 0.9.30.1-42
libgcc - 4.3.3+cs-42
libiptc - 1.4.6-2
libuci - 12012009.5-1
libxtables - 1.4.6-2
mtd - 12
opkg - 513-2
ppp - 2.4.4-5
ppp-mod-pppoe - 2.4.4-5
uci - 12012009.5-1
udevtrigger - 106-1
thanks in advance
AFAIK, you have to compile them on your PC and then upload to the router as none of packages are compiled on the router.
A ok, so, how to do this? can you explainme how to do that?, I don´t know how to generate an .ipk package for metarouter since my pc.
thanks in advance
you will have to ask that in OpenWRT forums i’m afraid.
Check on their site, you should be able to download sources and tools necessary for package compilation
I`think this are the sources:
http://downloads.openwrt.org/sources/
and these the tools?
http://downloads.openwrt.org/docs/buildroot-documentation.html
Is that the only way??
thanks in advance
all these questions should be asked in the OWRT forums, as they are directly related to compilation and usage of their software.
try
http://mirrors.muarf.org/openwrt-custom/metarouter/mr-mips/packages/
:wink:
