I have been trying to understand MetaRouter, and I have some questions.
Seeing as OpenWRT contains php, apache, etc, am I correct in thinking this could be used as a web server for using with the API on the main router? …instead of needing an external server?
In that same light, I assume then it would also be possible to use the same MetaRouter to run squid/privoxy/tinyproxy. In the main router’s proxy settings, you would then set parent-proxy to the IP of your metarouter.
Am I thinking correctly?
