Metarouter with SNMP crashes on RB1100AH
I’ve got several RB1100AH’s that we’re using for Metarouters. We need SNMP to work on these things, however whenever we enable it in the metarouter, the terminal hangs / crashes. Same deal under Winbox.
Tested on several different RB1100AH’s, with RouterOS 5.12 and consistently fails.
I’ve tried under 5.13, and it does seem to work there, but the ethernet interfaces flap, which prevents me from switching to that version.
Any thoughts on this?
Thanks,
Wazza.
I’ve got same problem. When I opened the snmp settings window, the (meta)router logged this error to the console:
fan: init
Unable to handle kernel paging request for data at address 0x000000c8
Faulting instruction address: 0x830b50dc
Oops: Kernel access of bad area, sig: 11 [#2]
RB MetaROUTER
last sysfs file: /sys/bus/spi/uevent
NIP: 830b50dc LR: 830b6d1c CTR: 00000000
REGS: 81b13dc0 TRAP: 0300 Tainted: P D (2.6.35)
MSR: 00029002 <EE,ME,CE> CR: 28000028 XER: 20000000
DEAR: 000000c8, ESR: 00000000
TASK = 81bb6000[232] ‘health’ THREAD: 81b12000
GPR00: 000000c8 81b13e70 81bb6000 00000000 1001bd18 00000004 1001bd18 300d1d94
GPR08: 0002d002 830c0000 8009da5c 800138e8 00000000 1002399c 00000000 00000000
GPR16: 00000000 00000000 00000000 00000000 00000000 00000000 10040000 00000000
GPR24: 7fe820e8 10004874 7fe82284 fffffff7 ffffffe7 00000019 830b8e1c 81b13e70
NIP [830b50dc] get_flash_sector_shift+0x40/0x6c [flash@0x830b5000]
LR [830b6d1c] flash_ioctl+0x13c/0x14c8 [flash@0x830b5000]
Call Trace:
[81b13e70] [00000005] 0x5 (unreliable)
[81b13ea0] [8009d87c] do_vfs_ioctl+0x56c/0x74c
[81b13f10] [8009da9c] sys_ioctl+0x40/0x74
[81b13f40] [8000e728] ret_from_syscall+0x0/0x3c
— Exception: c01 at 0x300cf36c
LR = 0x10001a04
Instruction dump:
2f800001 4cbe0020 80690024 5463aefe 4e800020 2b8300ff 7c601b78 38600000
4dbd0020 3d20830c 54001838 80698e50 <7d23002e> 7c630214 2f890000 409e000c
—[ end trace 7be857f3bb18a765 ]—
