Thanks for the responses. I’m trying to access the equipment remotely off site via NAT.
Below is my configs for the AP and POE.
750
add admin-mac=D4:CA:6D:D1:A0:59 ageing-time=5m arp=enabled auto-mac=no
disabled=no forward-delay=15s l2mtu=1594 max-message-age=20s mtu=1500
name=VLAN10 priority=0x8000 protocol-mode=none transmit-hold-count=6
add admin-mac=D4:CA:6D:D1:A0:5D ageing-time=5m arp=enabled auto-mac=no
name=VLAN20 priority=0x8000 protocol-mode=none transmit-hold-count=6
add bridge=VLAN10 disabled=no edge=auto external-fdb=auto horizon=none
interface=vlan10 path-cost=10 point-to-point=auto priority=0x80
interface=ether1-gateway path-cost=10 point-to-point=auto priority=0x80
add bridge=VLAN20 disabled=no edge=auto external-fdb=auto horizon=none
interface=vlan20 path-cost=10 point-to-point=auto priority=0x80
interface=ether2 path-cost=10 point-to-point=auto priority=0x80
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600
mac-address=D4:CA:6D:D1:A0:59 mtu=1500 name=ether1-gateway speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:D1:A0:5A
master-port=none mtu=1500 name=ether2 poe-out=auto-on poe-priority=10
speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:D1:A0:5B
master-port=none mtu=1500 name=ether3 poe-out=auto-on poe-priority=10
speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:D1:A0:5C
master-port=none mtu=1500 name=ether4 poe-out=auto-on poe-priority=10
speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:D1:A0:5D
master-port=none mtu=1500 name=ether5 poe-out=auto-on poe-priority=10
speed=100Mbps
/interface vlan
add arp=enabled disabled=no interface=ether5 l2mtu=1594 mtu=1500 name=vlan10
use-service-tag=no vlan-id=10
add arp=enabled disabled=no interface=ether5 l2mtu=1594 mtu=1500 name=vlan20
use-service-tag=no vlan-id=20
add address=192.168.10.10/24 disabled=no interface=ether2 network=
192.168.10.0
912:
add address=192.168.10.11/24 disabled=no interface=ether1 network=
192.168.10.0
add admin-mac=00:0C:42:BA:E7:F4 ageing-time=5m arp=enabled auto-mac=no
disabled=no forward-delay=15s l2mtu=1596 max-message-age=20s mtu=1500
name=VLAN10-HOTAIR priority=0x8000 protocol-mode=none
name=VLAN20-CORP priority=0x8000 protocol-mode=none transmit-hold-count=6
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
disabled=no forward-delay=15s l2mtu=65535 max-message-age=20s mtu=1500
name=bridge1 priority=0x8000 protocol-mode=none transmit-hold-count=6
add bridge=VLAN20-CORP disabled=no edge=auto external-fdb=auto horizon=none
interface=CORP-VLAN20 path-cost=10 point-to-point=auto priority=0x80
add bridge=VLAN10-HOTAIR disabled=no edge=auto external-fdb=auto horizon=none
interface=HOTAIR-VLAN10 path-cost=10 point-to-point=auto priority=0x80
mac-address=00:0C:42:BA:E7:F4 mtu=1500 name=ether1 speed=100Mbps
/interface vlan
add arp=enabled disabled=no interface=ether1 l2mtu=1596 mtu=1500 name=vlan10
add arp=enabled disabled=no interface=ether1 l2mtu=1596 mtu=1500 name=vlan20
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area=“”
arp=enabled band=2ghz-b/g/n basic-rates-a/g=6Mbps basic-rates-b=1Mbps
bridge-mode=enabled channel-width=20mhz compression=no country=
“united states” default-ap-tx-limit=0 default-authentication=yes
default-client-tx-limit=0 default-forwarding=no dfs-mode=none
disable-running-check=no disabled=no disconnect-timeout=3s distance=
indoors frame-lifetime=0 frequency=2412 frequency-mode=manual-txpower
frequency-offset=0 hide-ssid=yes ht-ampdu-priorities=0 ht-amsdu-limit=
8192 ht-amsdu-threshold=8192 ht-basic-mcs=
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any
ht-rxchains=0 ht-supported-mcs=“mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,
mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,
mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23” ht-txchains=0
hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=
00:0C:42:BA:E7:F5 max-station-count=2007 mode=ap-bridge mtu=1500
multicast-helper=default name=wlan1 noise-floor-threshold=default
nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key=“”
nv2-qos=default nv2-queue-count=2 nv2-security=disabled
on-fail-retry-time=100ms periodic-calibration=default
periodic-calibration-interval=60 preamble-mode=both
proprietary-extensions=post-2.9.25 radio-name=000C42BAE7F5
rate-selection=advanced rate-set=default scan-list=default
security-profile=default ssid=MikroTik station-bridge-clone-mac=
00:00:00:00:00:00 supported-rates-a/g=
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power=19 tx-power-mode=
all-rates-fixed update-stats-interval=disabled wds-cost-range=50-150
wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=
disabled wireless-protocol=802.11 wmm-support=disabled
add area=“” arp=enabled bridge-mode=enabled default-ap-tx-limit=0
default-authentication=yes default-client-tx-limit=0 default-forwarding=
no disable-running-check=no disabled=no hide-ssid=no l2mtu=2290
mac-address=02:0C:42:BA:E7:F5 master-interface=wlan1 max-station-count=
2007 mtu=1500 multicast-helper=default name=HOTAIR-VLAN10
proprietary-extensions=post-2.9.25 security-profile=default ssid=
HOTAIR-VLAN1 update-stats-interval=disabled wds-cost-range=0
wds-default-bridge=none wds-default-cost=0 wds-ignore-ssid=no wds-mode=
disabled wmm-support=disabled
yes disable-running-check=no disabled=no hide-ssid=no l2mtu=2290
mac-address=02:0C:42:BA:E7:F6 master-interface=wlan1 max-station-count=
2007 mtu=1500 multicast-helper=default name=CORP-VLAN20
Corp-VLAN2 update-stats-interval=disabled wds-cost-range=0
