Mib issues with PTP800s links
Good evening
I am using the supplied MIB from cambium links. The links are ptp820s. I found the OID required first I had issues with another MIB that was conflicting with it “Cerigon” Now when i query the OID i get no result but it matches the right MIB. If I place this same OID in the MIB walker “Subtree” i get a result and i see -52 which matches the receive level. But now the OID reads 3.6.1.4.1.2281.10.5.1.1.2.268451969. If the query this result it fails. Is there away to show a walk result in a label?
Thanks Steve
