How do you get a new Mib ( this is for a UPS ) into Dude?
thanks
rra
thanks
rra
Not too sure about using actual MIBS, but I would snmpwalk the ups ip and then check the oid against an online oid database for the ones i need.
Not sure about posting external urls here, but this is the one i use…
http://asn1.elibel.tm.fr/oid/index.htm
this is also handy
http://www.iana.org/assignments/enterprise-numbers
It is a bit time consuming if you are not too sure of the oids you are after, but the manufacturer might well have them listed on their website, but this is how I have configured my charts and it works well enough.
Hope this helps.
Apologies if it does not!! ![]()
Unfortunately snmpwalk does not seem to be working to this device, I do have the full mibs from the vendor, though…
robert
