Micro Flash and Store command for files
I have added a 8g micro flash card to my 433. It shows up in the store command and has been formatted.
Dose this become an extension of the on board memory ? or is it considered another drive?
The extra memory does not show up under the resources.
Will the user manager be able to use this by default or is some other configuration needed?
Has anyone seen an doc so the new store as I have a few other questions on how is being set up by MT.
Erik
after you configure it in Store, you can select it as a storage device in Webproxy. User Manager and Dude will also be able to use it in upcoming versions.
Thanks,
Hope my files don’t get to big before that’s ready!!! :smiley:
I suppose it been a while, when User Manager support for Dude is available.
Any time frame for this support?
Any hint as to how the new User manager is coming along ?
Erik
No timeframe for Dude, but it is planning in the upcoming version.
User Manager can be in the beginning of the 2009.
Thanks, UM is really where I need it the most,
Erik
