Has anyone seen an issue with 2.9.43 / 3.0B9 using Microdrives for the proxy storage?
I have used it in the past, would select “CF drive” in the drop down box for storage location.
It now only shows “system” as the storage point.. I have tested the drive in another system (a CF reader under XP) and the drive will format just fine…
Things that make you go Hmmmmmmm…
Craig
I have tried to reproduce your problem with Compact Flash and 2.9.44 version.
It was detected and I was able to specify ‘ip proxy set cache-drive=CompactFlash’.
Did you use exactly this MicroDrive in the past or another model ?
I used it (this drive) on this board uder 2.9x and it was seen ..
I noticed the issue after upgrading to 3.0B9…
Craig
Ok…
So I tried another MicroDrive (2GB Hitachi)…Same issue…
RB532, Hitachi 2GB MicroDrive, ROS 3.0B10…
Drive is not seen…
Hmmmmmm…
