MicroSD card initialization (on hEX S specifically)
I inserted the card (32 GB) into Hex S and it doesn’t get automatically detected. Am I supposed to reboot the device or there’s some incompatibility?
Can someone who owns Hex S confirm how deep the card goes into the slot? Mine sticks out by about 8 millimeters.
EDIT:
Yes, you need to reboot (actually it would make sense to insert the microSD card with the router off and then boot/power it).
BECOMES:
No, the card can be inserted with the router powered up and it will be added /sensed automatically (though actually it would make sense to insert the microSD card with the router off and then boot/power it)
You did insert it pins side up, didn’t you?
http://forum.mikrotik.com/t/hex-rb750gr3-micro-sd-not-recognized/142931/1
it’s sticking out too much, it’s more like 5mm.
you can see it the same instant in winbox , and afterwards you have to format it, but it shows up instantly as a removable device.
That was it, I inserted it upside down! Or actually, I put it correctly but the socket was upside down, for some reason. :slight_smile:
Info for future readers: it sticks out by about 3 mm on hEX S and gets auto mounted, doesn’t require reboot.
Or maybe you had the whole device upside down, I like the tic-tac-toe effect :wink: :
https://i.mt.lv/cdn/rb_images/1541_hi_res.png
I thought that it would not have been auto-detected, good to know, though I still believe that inserting and removing cards is better done with the device off.
Correcting my previous post, just in case.
