MicroSD Storage Expansion on RB433AH
Does anybody have any idea on how to install and use the memory expansion that can be installed in RB433AH using a microSD? ..
I installled a 2GB microSD memory, but it does get accounted for in the system/resource window.
Thanks.
I am have problem with card memory microsd 2GB Sandisk.
It will not get accounted there. It will be available as a proxy drive in “webproxy settings”, or in the new “store” menu
