I raised similar sort of question years ago but with new insights (maybe) and more experiences and wider availability of both types maybe some more conclusive statements can be made?
If given a same gain in dBi, which antenna is better? A microstrip one, or a eliptical (dish) one?
And now also; under heavy congested spectrum circumstances.
Say an 25dBi (Dynadish?) or 24dBi (QRT) antenna points in a direction for a backhaul connection but some other antenna is sending wifi radio wave in a close, or the same, frequency band from under and angle of lets say 25, or 45, or 60 degrees?
When we have a metal dish antenna, basically it shields the horn off from signals coming from behind up to an side angle to where the horn itself directly becomes visible from the side. This can be made better by using a radome shield (Like Jirious uses or you can buy separate from many dish antenna vendors Mikrotik included).
But a plastic dish like the Dynadish has, signals strong enough will just penetrate through the dish and still hit the cone?
In case the horn directly comes visible from outside the dish’s sphere how sustainable is it to pick up unwanted signals?
(The horn head is also a deflector, so it should only pick up signal coming from the sphere? This last puts a plastic dish is disadvantage compared to a metal one since the plastic one still allows radio energy from behind to penetrate and hit the dome head?)
Now look at a QRT. Basically all signals coming from an angle bigger than 90 degrees (so from the side to the back) are shielded off by the metal back plate of the microstrip print.
But signals coming from anywhere between 90 up to 5 degrees (so still outside its working beam) will still hit the microstrip.
So, both type of antennas will be picking up signals from unwanted directions. But which type is best in reducing the signal level from different angle than the projected one?
Off course I know its all about the S/N ratio between the signal to use and surrounding (and background) signals (or noise) but some times radios from 3rd party are hitting my antennas with signal levels almost the same as my own projected signal. So I have to use shields or randome covers and sometimes relocate antennas behind or around the corner of a building. But I am also developing more and more the feeling dish antenna’s are a better choice than microstrip to avoid unwanted ‘noise’.
Any intakes in this?
