Microtik Configuration
I really need step by step how to configure Mikrotik with PPPOE
i have Class C address
Thnx :smiley:
Welcome to Forum,
here you go…
http://www.mikrotik.com/testdocs/ros/3.0/vpn/pppoe.php
Dear Crown,
Please also look into the following page
http://wiki.mikrotik.com/wiki/Pppoe_server_with_profiles
Thnx for both of u
i have configure interface that is connected to WAN.
and then interface for our Local Network.
so can i configure all other stuff with winbox to make it easy or i need now all to do manually with commands
one last question
can i use this like switch or i really need to buy new switch
HI…
I the link that i gave you i have done every thing through WINBOX so if you feel that you can do it easily from command line then its up to you…however it is more easy to o it from WINBOX.
