I’ve recently purchased MicroTik RB951G-2HnD. Unfortunately I’m having trouble accessing my server from internet(outside). The internet is connected to ethernet1(wan) and ethernet2 is connected to a switch(unmanaged). All the clients and the server are connected to the switch ports. The public ip is 5.160.39.58/29 which should be forwarded to 192.168.1.21/24 port 7020.
I have setup the nat in the firewall but doesn’t work. Here is the config of the router:
nov/27/2016 13:48:56 by RouterOS 6.37.2
software id = 3QDX-7U8L
add admin-mac=E4:8D:8C:45:60:33 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/ip neighbor discovery
set ether1 discover=no
set bridge comment=defconf
add name=dhcp ranges=192.168.1.50-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge name=dhcp1
add bridge=bridge comment=defconf interface=ether2-master
add address=192.168.1.1/24 comment=defconf interface=ether2-master network=
192.168.1.0
add address=5.160.39.58/29 interface=ether1 network=5.160.39.56
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
add address=192.168.1.0/24 gateway=192.168.1.1
set allow-remote-requests=yes servers=77.104.106.2,8.8.8.8
/ip dns static
add address=192.168.1.1 name=router
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept established,related”
add action=drop chain=input comment=“defconf: drop all from WAN”
in-interface=ether1
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
add action=accept chain=forward comment=“defconf: accept established,related”
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment=“defconf: masquerade”
out-interface=ether1 src-address=192.168.1.0/24
add action=dst-nat chain=dstnat dst-address-list=5.160.39.58 dst-port=7020
in-interface=ether1 protocol=tcp to-addresses=192.168.1.21 to-ports=7020
add action=src-nat chain=srcnat protocol=tcp src-address=192.168.1.21
src-port=7020 to-addresses=5.160.39.58 to-ports=7020
add distance=1 gateway=5.160.39.57
/system clock
set time-zone-name=Asia/Tehran
/system routerboard settings
set protected-routerboot=disabled
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
Any help would be appreciated.
Thank you.
