MicroTik Routerboard RB2011Ui AS-RM
Hi
Could someone please assist with a Routerboard RB2011Ui AS-RM.
Here is the config file attached. Issue i have the device is very slow when in use. End users also complain about speed, once disconnected, access speed is fine
Please help if possible
Regards
supout.zip (248 KB)
use “/export compact”, not supout.
MikroTik RouterOS 6.12 (c) 1999-2014 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
(42313 messages not shown)
aug/26/2014 16:52:27 system,error,critical login failure for user root from 200.17
4.51.226 via ssh
4.51.226 via ssh
aug/26/2014 16:52:32 system,error,critical login failure for user root from 200.17
4.51.226 via ssh
aug/26/2014 16:52:33 system,error,critical login failure for user root from 200.17
4.51.226 via ssh
4.51.226 via ssh
aug/26/2014 16:52:34 system,error,critical login failure for user root from 200.17
4.51.226 via ssh
4.51.226 via ssh
4.51.226 via ssh
[admin@MikroTik] > /export compact
aug/26/2014 17:02:18 by RouterOS 6.12
software id = 51J5-C7US
add l2mtu=1598 name="1 and 2"
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
mac-cookie-timeout=3d
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
/port
set 0 name=serial0
/snmp community
add addresses=0.0.0.0/0 name=ppit_net security=authorized write-access=yes
add bridge="1 and 2" interface=ether1
add bridge="1 and 2" interface=ether2
add address=10.10.10.254/24 interface="1 and 2" network=10.10.10.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no
interface=ether1
/ip upnp
set allow-disable-external-interface=no
/lcd interface
set sfp1 interface=sfp1
set ether1 interface=ether1
set ether2 interface=ether2
set ether3 interface=ether3
set ether4 interface=ether4
set ether5 interface=ether5
set ether6 interface=ether6
set ether7 interface=ether7
set ether8 interface=ether8
set ether9 interface=ether9
set ether10 interface=ether10
/snmp
set contact=PPIT enabled=yes location="Die Stoep" trap-community=ppit_net
/system clock
set time-zone-name=Africa/Johannesburg
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set "1 and 2" disabled=yes display-time=5s
set sfp1 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
set ether6 disabled=yes display-time=5s
set ether7 disabled=yes display-time=5s
set ether8 disabled=yes display-time=5s
set ether9 disabled=yes display-time=5s
set ether10 disabled=yes display-time=5s
/system ntp client
set enabled=yes primary-ntp=196.4.160.4
Any help please ?
