Microtik --- Uplink sfp1 --- Cisco, (L2 , trunk, tagging)
I’m looking for advice regarding:
  1. Uplink configuration on Mikrotik Router the uplink with CISCO switch. In my case I have additionally one uplink with S1 built on bondage with 4 x Ethernet ports using VLAN XXX as manage and for uplinks. I want to connect second switch S2 (Cisco) via sfp1 port in L2 with VLAN XXX. How to configure such a second uplink in Mikrotik Router if the first one has been configured by adding in the Interface → VLAN option to a specific bonding interface, (4 ethertens). I do’n know how to add to the next interface sfp1 VLAN XXX and configure like in cisco “switchport access vlan XXX”?
    However, is there only a bridge configuration option left, as many people write in forums. How to configure it?
  2. Second bonding with a sfp1 and one Ethernet (1G) if possible. Also I don’t know if sfp1 and sfpplus can be in bonding. From the side of cisco will be ether-channel (Po1).
Attached simple diagram:
