might be a handy feature...
I use alot of cpe’s that use a webserver based gui to control parameters at the client site. It would be ever so handy to have even a text based web browser (i.e., lynx, w3m, etc..) built into RouterOS to overcome potential routing problems preventing direct access to cpe’s from remote sites. Such a tool would be used thru the terminal window and allow control access to cpe. I know it would help my situation! What say you? :slight_smile:
:smiley:
Source NAT can help in your situation :wink:
tunnel to router and you are inside your secure environment, of course, if you use encryption on tunnel :slight_smile:
