I want to move from a 2011UiAS-2HnD to a 2011UiAS-RM (both on v6.26).
The question is: how to do this?
- Backup/Restore: Have read that this is only for exact the same router (not even a router of same type)
- Export verbose: Can´t import, tried it by /system reset-configuration keep-users=no no-defaults=yes skip-backup=yes run-after-reset=fullexport.rsc. System is resetted but comes up with no config at all. I guess the missing wireless causes this problem
- Export compact: Comes up after reset but there is some config missing (Identitiy, Users, SNTP client, LCD settings, ???)
So what´s the way to go? Export compact would be okay if I would know which settings else are missing.
Martin
