I try to move my settings from rb450g to rb1100ah by command
[admin@MikroTik] 450g> export compact file=test
and
[admin@MikroTik] 1100ah> import file=test
when i finish everything in my new device i dont have internet. How can i repair that?
Go to the log and check if it stopped importing because a line failed due to hardware differences. You’ll have to fix the line and reset the unit and start all over again. There might be many fault lines but keep fixing them until the scripts ends with success. I believe there might be a better way and maybe somebody has a better idea but right now that works for me when transfering machine setups.
Sent from my iPhone using Tapatalk
just fixing internet?
ip route add gateway=GW
