Migrating Caps-man Configuration to New hardware/4011
Trying to move Capsman settings to a different device with mixed success. Looks like only some of the config is sticking on import.
Possible mac addresses conflict.
/caps-man export then import the best way to do this?
If you have dynamic interfaces should you edit out/ remove the /caps-man interface from the script?
Any experience or advice?
Hmmmm
Error is “input does not match any value of datapath.bridge”
Bridge name was exact same on both devices.
I took out all datapath values and it imported successfully
