I am new to the field and new with MikroTik.
I have a configuration from a cisco router, which I shall migrate to a MikroTik router.
In line with the migration there are also some changes on the ipsec tunnel security configurations.
old cisco configuration:
crypto isakmp policy 9
encr aes 256
hash sha512
authentication pre-share
group 16
crypto isakmp policy 10
encr aes
group 14
crypto isakmp policy 50
encr 3des
hash md5
crypto isakmp key address 10.0.0.56
crypto isakmp invalid-spi-recovery
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode tunnel
crypto ipsec transform-set AES-SHA esp-aes 256 esp-sha512-hmac
mode tunnel
crypto map SDM_CMAP_1 1 ipsec-isakmp
description tunnel to other server
set peer 10.0.0.56
set transform-set AES-SHA
match address 100
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address 192.168.55.156 255.255.255.0
duplex auto
speed auto
interface Vlan1
description subnet test.server
ip address 172.16.75.1 255.255.255.0
no ip redirects
ip tcp adjust-mss 1452
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.55.10
ip route 172.16.75.0 255.255.192.0 172.16.75.10
new MikroTik confugration:
model = RB750Gr3
add name=bridge1
/interface vlan
add interface=bridge1 name=SVI-vlan vlan-id=1
add name=WAN
add name=LAN
/interface lte apn
set [ find default=yes ] add-default-route=no ip-type=ipv4 use-network-apn=no \use-peer-dns=no
/ip ipsec policy group
add name=test_group
/ip ipsec profile
add dh-group=ecp384,ecp521 enc-algorithm=aes-256 hash-algorithm=sha512 lifetime=8h
name=ipsec_test prf-algorithm=sha512
/ip ipsec peer
add address=10.0.0.56/32 comment="ipsec_tunnel" exchange-mode=
ike2 name=ipsec_other_server profile=ipsec_test
/ip ipsec proposal
add auth-algorithms="" enc-algorithms=aes-256-gcm lifetime=1h name=
IKEv2-proposal pfs-group=ecp521
/ip smb users
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/snmp community
set [ find default=yes ] encryption-protocol=AES name=mikrotik_snmp
/interface bridge vlan
add bridge=bridge1 tagged=bridge1 untagged=ether4,ether5 vlan-ids=1
/interface l2tp-server server
set default-profile=default enabled=yes use-ipsec=required
add interface=ether4 list=LAN
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether5 list=LAN
add address=192.168.55.156/24 interface=ether4 network=192.168.55.0
add address=172.16.75.1/24 interface=interface=SVI-vlan network=172.16.75.0
set servers=1.1.1.1,8.8.8.8
add action=accept chain=input port=500,4500 protocol=udp
add action=accept chain=forward connection-state=established,related dst-address=
172.16.30.0/24 src-address=172.16.75.0/24
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=srcnat dst-address=172.16.30.0/24 src-address=172.16.75.0/24
/ip ipsec identity
add peer=ipsec_other_server policy-template-group=test_group
/ip ipsec policy
add dst-address=172.16.30.0/24 peer=ipsec_other_server proposal=IKEv2-proposal
src-address=172.16.75.0/24 tunnel=yes
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.55.10 routing-table=main
add disabled=no distance=1 dst-address=172.16.75.0/18 gateway=172.16.75.10
routing-table=main scope=30 target-scope=10
/ip service
set www disabled=yes
/ipv6 nd
set [ find default=yes ] advertise-mac-address=no disabled=yes
/routing bfd configuration
add disabled=yes interfaces=all min-rx=200ms min-tx=200ms multiplier=5
To test my new MikroTik configuration I used three MikroTik routers (one for each ipsec tunnel endpoint and one between them). The ipsec tunnel forms and is stable, but I have issues with the communication through the tunnel. I have a client on each side of the tunnel, but I cannot reach anything.
Nothing worked so far. Could someone give me a hint or some advice on how I can implement this.
Thanks!
